extended lines towards a bow do not stop
  • Thread starter Thread starter Giovannino60
Giovannino60
I've extended lines to make her lean on a bow but the lines don't end right on the arc but they go further, I attach image, it's normal how to make her stop right on the arch?
will be a question of image definition.
check in the options the accuracy value of circles and arches. the lower the better the performance but the more gross the visualizations of the curves (if you impose it to 2 for example you will see a polygon).
Also when you approach an intersection that involves a curve always make a regenerate, so that it redefines the accuracy of visualization.
