external gas thread
  • Thread starter Thread starter teoros
teoros
hi guys, I use proe wildfire 3 yesterday.
I read the discussions but I did not find solutions.
if I have to do an external thread (cosmetic) for example from 1/4"gas, is the process always equal to the following?
- insert
- cosmetic
and I follow the following entries:
1. sup filetto
2. initial sup.
3. direction direction
4. depth
5. diameter (I always have to insert the diameter of hazelnut? )
Then I wonder, but how do you know it's not a metric thread? or when I go to quota it proe know that it is 1/4" gas?
ciao,
Yes, put the diameter of the core.
to tell pro-e the type of thread you can use cosmetic > note param, where insert the text that you will then go to recall in the drw.
ah therefore if it is an external metric thread or gas does not matter. I must always insert a note with writing the filet type with its step.
then in putting this value into the table I must insert it manually by looking at the note?
Thank you very much
thanks after I try to insert the note. But it's a little uncomfortable, isn't it?
