genesis1975
because I did it again this morning. ..between the other identical to what made me mistake... did you see that in the bottom bar there were two overlapping sw icons? the other is that of a part I divided
eh? barra in basso?Did you see that in the bottom bar there were two overlapping sw icons?
I mean? What part? Where?the other is that of a part I divided
then qunado opens the axieme opens any file to which there are references. those inside the axieme does not open them because they are already loaded while braking in the axieme is not physically present therefore comes1.all(i.e. opens all documents reported externally)
if there are external references there is the text "->". if the references are not resolved there is the text "->?". the first advice I give you and not to make multiple references and not to wrong, disable this possibility in the options. In this way the work is cleaner and the references of a part will be within a single set. If you have questions, to see if it's a problem, you need to open the reference aid. to do so simply click the incriminated sketch on the feature manager with dx key and select "contextual display". If after opening the axieme the references settle and disappear the "?" means that it's okay. If you don't solve, you have to investigate and there are 2 things to do for sketches:I exhume this discussion to ask you how you can quickly understand, when it happens, what are the references of a sketch out of context, with the fact that they do not color differently from others, brown for example when references are disconnected.
If I right-click on the sketch and select the item "external references" I open a list, but the individual entries in the list are not selectable individually, and if I filter only those out of context, selecting the list these are not highlighted.
Therefore I have nothing but to click on the individual sketch lines and look for which references have the point of question side by side. .
the problem is when none of the lines has references with question mark, but the sketch continues to present a reference out containment and I miss half an hour to find it.
I use the top down based on skeletons for 20 years and I have to say that once I fully understand the mechanism, the software never behaves abnormally, it is very reliable. the tools to manage external references there are and the axioms in topdown are manageable, even in the case of clones, partial clones, rename, etc... for each situation there is its command or we have developed a procedure that allows us to maintain external references without disconnecting them. Obviously there must be the conditions for their maintenance.external references in sketches is unfortunately the basis of my work, I realize piping on skid, and reporting the sketches of the structural to piping allows me to have a skid that automatically adapts to the change of piping.
each frame has at least 2 or 3 sketches for the structural elements with a total of 10-20 references to the piping that is in an external set.
to derive similar plants work always of pack and go, but it can happen that some references present the point of question and it is not always simple what is the quota or relationship that is "hijacked"
I will try to use this, but the nose still lacks something to the software to be very helpful in this sense.
2- Enter the sketch, press shows/delete reports and in the first feature manager curtain select "defined in context". with this filter only see those with external references and you can investigate one to which are the reference entities or delete the relationships that for some reason cannot be repaired.
