extract count, name and geometry of blocks in a region
  • Thread starter Thread starter tecnodoff
tecnodoff
Good evening. . .
I would like to know if there is a lisp ke allowing a certain region of design to extract the distinct blocks present (name and number) and the respective dimensions (non dynamic blocks).
example: select a window in the drawing and then appear to me the name of the blocks present and their quantity (block to: 5 block b:2 etc.) cn the relative size (length x=500; y=700 etc.)
I can tell you, it's a good grain. .
thanks to all
by name blocks and quantity you can use bcounts (expresstools), if you want the size you need to use it.
t thank x the timely reply but extracted cn it is not possible to extract the geometry of the block if nn has been parameterized before....or at least I think... .
for bcount nn I have et installed...no other way??? ? ?
Is there any way to extract even nested blocks inside other blocks with a tree report?
