extract ipt file properties in txt file
  • Thread starter Thread starter windreef
windreef
Hello everyone,
it is possible to extract the iproperties of a group of files part .ipt (including custom ones) in a txt file. I have tried with design assistance but does not extract the customized ones. :confused:
separate custom? :confused:
I never did, I have a look in the morning if I find it then I'll let you know.
but by inventor or design assistance ?
Thank you very much
I was doing everything as an inventor, sticking the parts I needed in a temporary set, making the distinct base and saving it in excel. then from you can do everything and if I don't remember badly instead of saving it in excel saves it also in other formats even in a database access.
My components had a tide of custom fields: heat treatment, crude, supplier, brand, code, hardness, weight, surface finish, drawer, date etc etc etc.
Okay, I get it. I'll try right in the morning. I'll let you know.
Thank you very much
Please and have a good time;)
I tried, but it only shows me the custom properties of the axieme (as fields I mean) while in the part I have inserted more than the model of together.
I could do it piece by piece, and then join them in excel but they are a few hundred parts it could take me a few days, besides the risk of madness:biggrin:
hello anyway
hello anyway
depends if you make the distinct first level, only parts etc... There are settings of how to make the difference, what to consider if you assimilate and sub-assisted and parts if only parts ... look at us well:finger:
Okay.
at this point Monday:biggrin:
