extract text in a txt file and indite it
  • Thread starter Thread starter vascoda
vascoda
Hello, everyone! I wanted to ask for feasibility or not of something. I would like, with catia 5 r20 to extract in a file, for example txt, all the text present in drawing 2d. Let me explain, suppose we have an electrical circuit where there are resistance values and they want to edit by replacing them with other values. say that it is possible to take all the text, "put it" in a text file, edit it and then resume it inside the drawing? ?
Suppose we really have to do such an operation on so many designs, not being able to do as I just said, how could you do it?? knowing that each design is different from another.
thanks for your collaboration! ;)
definitely with a macro that edits and changes the text in the various files.................. :smile:
But you have to find who can do it.
cmq is the command find text and replace if you want to do it manually (ctrl h)
under the change menu :wink:
Thanks to the mcbramby answer, look, the problem is more complex but you know:( because imagine a thread whose extremes are now called a-a I would like to call them a-b for example, so unfortunately with the substitute I can not do it, and with the macros.... look I don't know why every design is different from the other! :(maybe you can but I don't know how.... :
I don't want to go into this because I don't know the problem......... but the example you've done doesn't seem like an obstacle....... find a-a and replace a-b :smile:
But I do not know, as I repeat the problems you have, there are certainly many + variables
cmq even if you do a macro do nothing but look for a text and replace it with another............... It is obvious that if you have 10 a-a texts and only 4 must be replaced, you must "train" the macro to do what you want, while with the command you look for a text at a time and replace only those you want.
if it is not top secret mail an example you would like to make......... :finger:
