extraction property
  • Thread starter Thread starter Luca.Scalco
Luca.Scalco
Hello, I wanted to know if it was possible to extract in excel of the properties of multiple files part with the same properties.
for example having a folder containing a hundred cn files the same properties (also customized ) as mass, height, thickness, file name etc. if it was possible to extract them in an excel file with a unique command, without opening each file.
In my case I have a folder with a hundred sheets created in file part of solidworks and I needed to extrapolate several data contained in the properties, such as finished sheet height, flat plate height etc. some of these custom sn properties and not by default of the program.
thanks in advance for the attention!
first, the most trivial thing is to create a set and drag you into all parts directly from the explorer folder (drag&drop); non via insert component.
then phase a distinct material
can they have a good idea, as an alternative if there was a macro that would allow me to do the required one would be more automatic.
