pasquale83
Hello, girl.
I'm playing a little with inventor trying to figure something out. . .
I am almost good with solidworks, which as philosophy should be close to inventor.. .
are the first days ... and there has already been a difficulty
I am trying to achieve some kind of bearing support like that in figure:
but with the fixing plate to 4 holes and with the narrower cylindrical body of the plate
I designed and extruded the plate first,
now I have realized the "on a face" sketch of the plate to extrude the cylindrical part
but between the various commands I did not find the possibility to extrude with offset from the face (both starting and ending)
in solidworks was very easy and intuitive, just select "from the face with offset" and "to the face with offset"
here it seems not possible
should I extrude between the two faces and after making a subtraction of material?! :4404:
but with the fixing plate to 4 holes and with the narrower cylindrical body of the plateI designed and extruded the plate first,
