3DL.L.
Hello, everyone. in solid works the k factor changes according to the thickness of the sheet or is it possible to put a value that suits all sheet thicknesses? I explain better, working in the past in a firm that used solid edge, it used a unique value that is called a neutral factor the value seems to me that it was 0.2730 and for the thickness plates between 1 and 2 it was fine. Now I’m using solid works I think the k factor should be a different value for each thickness. I ask for clarification and thank you in advance
