failure of workpiece
  • Thread starter Thread starter meacmae
meacmae
Hello everyone, I'm learning the underline.
I have this file attached to which I have to do the processing but I can't.
Who gives me a hand?
1) Congratulations on the thread title!!
2) congratulations on the description of your problem
3) compliments for not complying with the three basic rules (up of a thread) (which I suppose you have not read) of this forum.
I'm sorry if I wrote the title case, I didn't want to scream.
for the up if you look at the dates you didn't need to uppare the message but because I thought a picture would clarify the problem and post it immediately after.
If I made other mistakes, I apologize.
If you want to delete the post (no one helps) remove it as well.
Sorry.
Sorry.
the title is incorrect not for the format but for the voice "help".
in the title you try to synthesize the problem, but with "help" you create a thread too generic and in case of solution it is not filterable through searches on the site.
If you want to attach/modify the post, you have 15 minutes to do it.
I don't run anything, I just ask you to specify what kind of help you want.
I don't know the program but there are many users who can help you.
once you have explained the title of the discussion (if I understand what we are talking about:biggrin:)
the problem is the failure of the piece.
the file I attached is the final work piece as it should come while the attached photo is the processing that comes to me.
I think it's a problem of type of work.
to cut this piece you need the part of 3d ml.
Do you have it?
Hello bulinorotto,
The 3d module has it,
can be seen from the photo that has attached, in the list of operations
those are 3d jobs.
about the piece, you might like to do it in two shots,
the first processing taken vertically,
the second lying with round canal and various rays left before.
