epasinet
boys, some good soul, can tell me if in archicad you can realize uneven covering falde that is with non perpendicular angles? I attach an example in which I used the tilted layer tool but as you see it did not give me the hoped results. I would like to realize this simple two-phalt cover but as you see from the attached design the bonfires in the plant are not perfectly rectangular!
thanks to all
thanks to all
