family table
  • Thread starter Thread starter fafuec
fafuec
Good evening
I have a problem I created my first family table.
I entered the general in a folder.How do I tell the program to go to load the component from that folder? What do I have to vary in the config pro? You'd tell me every step.
I have a w2
proe/creo always works in the set directory, if you want to recover parts or assemblings from other folders or look for them manually or you need to set the search directories in the config.pro through search options... (typically set on library folders). I don't understand why the family tables you need to store them in other locations.
hoping to have been clear enough, greeting
aminati
insert into the config.pro string:
search_path c:\aaa\bb\ccc
search_path c:\aaa\bb\ccc\ddddd
a row for each folder and subfolder where you saved lever parts.
obviously replaces b c d with the correct routes.
I hope I've been helpful
Hi, ptc... I see you're busy.
However, a presentation to other members would be appreciated.
Be careful about the date of discussions.
this for example has been steady for several months.
I apologize maxopus for the answers to the threads a little "old" if they are to be considered such.
I think, perhaps mistakenly, that if at a thread there are no answers or if these are generic an approach is not wrong with the intent to improve the forum perhaps with 3d models and concrete solutions since they are scarce.
wikipedia owes its success to this, it is very dynamic, and that's why it turns out to be the first indexed on all search engines.
as they say... a caval donated... .
Anyway, I'll be more careful, and I'll be right there.
Sorry about the fugitive interference.
