driver
Hello, everyone.
Is there a way to draw it? using helical protrusion maybe?
I'm not sure exactly, but maybe you could use it.Hello, everyone.
I have 2000 pieces and snaps already without screws!I made a screw with normal thread (by setting the value of the hole necessary because threads) and then I added a non threaded cone representing the tip.
using protusion is fine if I have to model a screw for a factory making screws
If such a life I put it in a set that counts 50... all snaps a little.
You must always draw what you need! (what learned in time)
I've been looking at the pictures, and I understand why you put two protrusions in the dot? Thank you.follow pictures
