expcic
Good evening,
I need a little help.
I am conducting a static-structural fem analysis on a structure that is fixed by screw+washer+shaft+nut.
I want to know what type of displacement bond should be imposed on the nodes of the structure area in contact with the two washers (which are pressed against the structure due to the tightening of the bolt).
I have imposed a complete ink condition for the area concerned. the analysis does not give strange results only that in proximity to the washer there is a peak of tension that I would like not to attribute to wrong conditions of bond.
to note that at the moment it is not interesting to know the stresses to which the screw is subjected.
I would ask you to give me any help because on the basis of this I must make very important technical choices
Thank you very much
Thank you very much
