Ing.Vedder
Hello everyone,
I come in search of help here from you because I have come across a field of which I know little or nothing... the fearful dimensioning to fatigue.
First of all I have already searched on the forum but I have not found much, I put the problem to you.
through a static analysis using fem software on a plate of a bolted flanged joint I found the tension of von mises in an area of this plate. the joint during his life will be urged to fatigue button r>0 for numerous cycles (>6 million)
This voltage of vm (precisely 185 n/mm2) is close to the admissible sigma (190 n/mm2) for a common carbon steel (s275jr or fe420 more or less same thing).. and the peak point is right next to a drilling for a bolt of the plate (point of voltage concentration close to a drilling on a plate).
turning online I saw that for the above material the curves of wholer give an infinite sigma to life of 210 n/mm2 (see attached image).
Is that enough to feel calm from the point of view of fatigue?
do you have examples or guidelines to suggest? I sail a little in the dark. .
Many thanks to all
e.v.
Many thanks to all
e.v.
