PabloPicasso
use autodesk inventor for designing assimi parts in 3d and I have been trying for some time to use the integrated fea module.
I should calculate the torsion rigidity of a tube frame in ft*lbs/deg
Suppose the frame is a simple square, the method I used in the fea analysis was to "block" two corners of one side and apply a force (say 100 n) on the other two, but in reverse way to create a torque moment.
the results I obtain however are only in mm of deformation and mpa (von mises stress)
Can you help me?
Can you help me?
