feature for rings viewers
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,
I wonder if there is a library of ifeatures for seeger rings, both internal and external, as input there is only to give the distance from a reference face and a click on the cylindrical surface to work? :smile:
I can't hide that I tried to do it myself but I couldn't.:frown:
Hello everyone,
I gave up months ago...
You gave up looking for them or doing them? :confused:
I tried in every way to farm them, but nothing. I seem to remember that I could not set a point of insertion such that the quarry was in interference with the line of the measurement of the quarry - width seeger.... .
Of course it is a :3559: marvel :3559: that normalized processing does not appear in the cc....
I don't put files because they contain business references, but:
  1. create a part with d_albero =3 estrusa 20.
  2. create a plan for example 2mm from the edge.
  3. create the excavation feature, do not project the edge but draw the 2 circles you will say dx=d_tree d_int=2.8 h_cava=0.5.
  4. create da questa una ipart, la ipart avrà in tabella d_albero,d_cava, h_cava, dx.
  5. extract a ifeature, take behind the tables of the ipart and the sketch plan, you will already bring the correct values and correspond the table things between the various diameters and hollow heights, forget the insertion point, insert your untied ifeature, so much will be comq in the center, in case you edit the sketch and you will win.
I based the example by reasoning on external rings for trees.
I hope I've been quite clear. . .
Hey, how's it going? It was so much that you didn't read, I try and let you know...:biggrin:
All right, very busy from work homes and motorcycles... :
I forgot.
4.1 compile the ipart table of all values
6 save iparts in a folder for future use
Yeah, well, halfway, if I pull out with the ipart, then it doesn't make me change the parameters when inserting the ifeature. . .
explained, in ipart table you must have compiled the 3 fundamental columns, d_est, d_int and h_cava.
I'm pointing out the selection in the ifeature you only do it on the d_est and he fixes the data related to the other 2 parameters
Yes, I have compiled them, but when I go to insert the ifeature, I appear to be edit fields different from the usual (perhaps because dependent on the ipart) that
cannot be edited.. I'll get the picture.
another thing, always on the gorges:
a square groove, or another similar workmanship, thickened in cc processing, has automatic diameter recognition, i.e. just click on the cylindrical surface where I want to do the gorge, it is used to acquire the diameter.
Who knows if it would be possible to reproduce this in a ifeature? .
all values.... select the d tree and should update the other 2 from table
I tried to make changes or replicate that quarry there, but nn m managed. between the other often I can't change as I want the other 2 parameters.
and then I say to him in substance only the tree, to the rest, of inside and hollow height I do not want + think about it. . .
Okay, but in the end you first turn your throat for revolution directly on the side..... .
