Roxkill
Hello everyone,
using catia v5, I have a problem before getting to create a cinematism of an arm with ammotrizer.
to sum up I created an example, where when I go, after entering the step (selecting the length), to define the length of the propeller, with the command "measure between", then select the plans created both parallel to the xy plane, one at the initial point and another at the final point of the propeller.
at this point I go to update but it gives me as error three:feature involved in an update cycle :mixed:,
if you do an update of the .zip file (file created with the v21) attachment you should have the stress problem.
where is wrong?
Greetings to all.
Greetings to all.
