Framby1983
Hello.
I would like an opinion from those who like you know more. I have the problem briefly.
I have to check if a container carrying a certain load (for accuracy n.6 engines of 270kg/cad) can be stacked statically for a maximum of three. (as in the photo attached).
had to insert gravity I thought well to apply it to the center of the configuration; by turning the calculation the results are not convincing at all (see photo), as if only the central container took all the contribution of gravity.
I ask you, what am I wrong? Should I apply gravity to a surface and not to the center of gravity? if what?
ps: I assumed that I must necessarily apply gravity otherwise the software does not recognize the weight that the two containers discharge on the pillars of the container supported on the ground. Right?
