Simsto
Good morning to all,
I find myself asking for help from all of you about a probably trivial problem but cause confusion.
I have to carry out by fem a linear static analysis of a circular cylinder immersed in a pipeline run by steam overheated.
the cylinder is positioned as a bounce, with its axis positioned orthogonally compared to the steam flow lines.
My problem arises in attributing the correct loads of force and/or pressure on the outer surface of this cylinder.
I know that the viscosity of the steam fluid would tend to drag the cylinder if it was not bound by the structure.
the forces at stake therefore are due to a difference of pressure between the semicircumference invested by the upstream fluid and the downstream fluid.
speculating that the steam pressure is 8bar, I calculated that the p-resistant is approximately 1bar (using as a cross section of the cylinder).
which of the various assumptions is correct?
1) impose a pressure on the semi-face upstream (8+1)bar and on the semi-face downstream 8bar
2) impose a pressure on the semi-face upstream of (1)bar and on the semi-face downstream 0bar
3) impose on the half-face up a pressure of (8)bar and on the semi-face downstream (8-1)bar
that is, the pressure deriving from the resistant force is to be set in addition to the hydrostatic one of the upstream steam or to be subtracted in the downstream one?
thank you very much in advance, if you need more details the delucidations
