field string display connected to a property
  • Thread starter Thread starter MaxiPT
MaxiPT
Hello everyone,
I would need to intercept the link string of a field connected to a property.
when a field is inserted a string in code type "% .....%" that connects the field to the property or date etc.
the field returns to video the value assigned.
I need to intercept the strings instead to see the various fields as they are connected.
Is there any variable or method to access the display of the inserted string?
domenico, the direct link to the file seems not to work, I insert that to the site: field objects | lee mac programmingit invece maxipt vulole semplicemen'access the display of the inserted string" can with double click on the field and then, again, double click on the text, recall the window of the fielddata
thanks for the link lisp but I see that it does not work for custom properties (dieva).
regarding the double-click (gp) change to you works for changing fields related to custom properties?
the string link should be like
%<\acvar customdp.code> %
but by double-clicking does not find the link to be able to change it.
Is there any variable or method to access the display of strings connected to the custom properties inserted?
