file configuration to export to parasolid parts
  • Thread starter Thread starter Pal_65
Pal_65
Good morning.
a my client has a mazak milling machine (i-300s model) that directly uses .x_t file (parasolid).
I can't transfer my files properly.
Surely there are configurations (parasolid_config.pro or something similar) to set up.
Thank you so far to those who can give us directions.
I add more information.
the version of parasolid to export must be 9 or 10.
Thanks again
Good morning.
I would also like to add how fie is configured:
" parasolid_config.pro "...
Thanks again.
Good morning.
hi pal_65 the variable to set in the config.pro for export in parasolid
is "intf3d_parasolid_export_schema".
this variable allows the user to choose the scheme to use for export
in parasolid. by default is sch_10004.
I recommend you consult the online guide to know the other settings
valid pattern.
as they are different it will be appropriate to perform some tests to find the setting
Right.
jambo
Thanks jambo.
the various options sch_1------ I can't crack them.
The online guide is a bit lacking.
Thanks anyway.
Good morning.
for those interested, I am trying one by one, the 50 and passes proposed configurations for exporting files
"parasolid *.x_t" .
I will keep you informed about the correspondence with the " parasolid 9" version required to interface correctly to
mazak milling machine (i-300s model).
I hope soon.......
Good morning.
I checked the 51 configurations.
negative outcome.
pro engineer does not communicate directly with mazak milling machine (i-300s model) through parasolid.
If there are other paths I can't understand.
