file modifications on pdm in block
  • Thread starter Thread starter Sp4rk0
Sp4rk0
hello to all, I wanted to know if you can change the same property in block on multiple files in the pdm.
In practice, for certain types of product we have to add certifications required by the customer, to date the pdm automatically does it to the creation of the file according to the encoding, for example on laser cuts automatically puts nesting certifications.
my problem is on old files already made, on all cut pipes I should delete the certification put before by mistake, I would like to know if I can select multiple files simultaneously and delete the certification or, in case of need, add it.
Maybe someone has a script or method to do it, if you use the built-in solidworks pdm.
