file name in iproperties and numbering parts
  • Thread starter Thread starter Pano
Pano
it is possible to ensure that the file name of the part or together (type xxx.ipt) is saved in the field Title and not in the field Number of iproperties?
other thing: Is it possible to progressively add a number to an iproperties field to all parts that make up a set? type: assieme1-001, assieme1-002, etc.
My goal is to have the cartilages of the masses at the table in which the field Number contain this progressive numbering.
Now I'm opening one part at a time, in the field Title I copy the file name and the field Number I bring the numbering back.... can you, then, do it automatically?
ipart:
if you publish it yes.
executing the content center editor modifies the table and impose an equality between the file name column and the title column (which you will have inserted in the ipart table).
numbering:
the vault pro allows you to create a numbering scheme as it serves you.
without a vault you need to know how to build the axieme. the thing you ask you could do if, in the axieme, you use the create part and then you create the assembling in this way (top-down design). What is different is if you insert the various parts already drawn into the axieme, in this case the name you have already given to the parts so it is difficult to go to change this property.
in any case with ilogic you could write a rule that does what you ask.
