file opening
  • Thread starter Thread starter saralb
saralb
I need help,
I can't open catia part file, it always gives me the following error for all files.
Could it be that who the warrant did not annex everything?? or is it a newer version of mine? ?
This is what appears to me:
mpossible to open the file
c:\documents and settings\alberto\desktop\prova\prova1.catpart:
invalid application level
Yes, that error appears when you try to open a newer version. . .
years ago
years ago
Hello, gianni, thank you very much for the answer.
If it still happens to me in the future how can I solve this problem?, is there any solution or should I do as I now request the file in a version compatible with mine?
Thank you very much
There is no other way to send files in the same version, or in a neutral format.
However go, export in non-original format involves loss of history.
is good standard for a supplier to use versions aligned to the customer and do not upgrade to higher versions if not on customer's request.
in case you were the supplier, you should align (if you have other customers, install multiple versions, but be careful in management).
