file .rst
  • Thread starter Thread starter ygna
ygna
I saw in the guide that the .rst file contains all the static analysis solution but can't open it as I can do? I have to find the participant mass of a modal analysis
Try this file.
ansys alerts, files -> read input file -> input.txt
Pay attention to the .cdb file path
Good work...
Ask. ask and ask...
did you try the file I sent you?
"I tried but nothing changed..." can not be so ..
a file named "file_prova" in a position that you clearly "define" is created ... see file input.txt
you have the solution to your problem, if you don't see it... help you to help
I opened ansys the file I'm working with and from file -> read input file -> input.txt is launched the analysis but no file is generated containing the values I sought... .
Did I tell you to open the file you're working on? No.
did you try to open the file I sent you (for the input.txt)?
What is simulated with my files?
If you don't answer these questions for me help closes here...
ecco gli errori che mi da...grazie per la pazienza
/com,ansys release 11.0sp1 up20070830 15:02:49 08/29/2012
/com,ansys release 11.0sp1 up20070830 15:47:46 08/29/2012
/com,ansys release 11.0sp1 up20070830 16:12:00 08/29/2012
/com,ansys release 11.0sp1 up20070830 16:15:16 08/29/2012
/com,ansys release 11.0sp1 up20070830 09:09:01 08/30/2012
*** warning *** cp = 2.371 time= 09:09:37
file modale.cdb does not exist for the cdread,db command.
the cdread command is ignored.
*** warning *** cp = 2.418 time= 09:09:37
output file cannot be opened - file name=
d:\test_forum\modale1\file_prova.out
due to error number= 30
check file permissions, and also ensure that the file is not a
directory.
*** error *** cp = 2.418 time= 09:09:37
there are no nodes defined.
/com,ansys release 11.0sp1 up20070830 10:23:33 09/01/2012
*** warning *** cp = 4.181 time= 10:27:20
*** warning *** cp = 4.259 time= 10:27:21
directory.
*** error *** cp = 4.290 time= 10:27:21
*** warning *** cp = 4.602 time= 10:29:58
*** warning *** cp = 4.618 time= 10:29:58
directory.
*** error *** cp = 4.649 time= 10:29:59
as I suspected. You didn't even try to understand the error/warning that is shown to you....
It is not a matter of patience but of good will...
start by formulating questions where you understand that you are putting on your .... at that point the help will not miss...
Good job
I wanted to warn you that finally, after several attempts, I managed to have the .out file with all the results of the analysis
file - switch output - file - analysismodale. out
