file stp
  • Thread starter Thread starter CODY
CODY
good day, I have to import some stp files sent to me from a supplier, the program you use is thinkdesign.
the problem of the supplier is that it has difficulties in converting files to stp format, so when I open them they are corrupt, it tells me that for each file it takes more than two hours.
know if there is a file converter from thinkdesign to .stp
the software I use is one space design:bekle:
if it is axiemi not too big test with acis (sat).
Unfortunately it only manages the single model and then you have to reassemble everything in osd.
But it takes two hours because it's a big file or why it's jammed?
the best way to send a set out is undoubtedly the stp format.
if the set is great you need to generate multiple stp files (max 50-60 mb to avoid problems) dismembering the together in different sub-assembles.
