emanuele grasso Guest Mar 23, 2022 #1 Hi. on drawing I exported a dwg of a cartiglio and emptied me every letter Is there a way to fill them? Thank you. Attachments LETTERE.webp 5 KB · Views: 7
emanuele grasso Guest Mar 23, 2022 #4 I put semantic but the result does not change.. the letters are always empty:
Vittorio Guest Mar 23, 2022 #5 if you carry out semantics and open the dwg with catia letters are full with what software then read the dwg?
Vittorio Guest Mar 23, 2022 #7 But then, if you read it with catia it works! I tried and it works, it has to work for you too
Vittorio Guest Mar 23, 2022 #9 if it is not a copyright thing tries to send an example of that text in catia format. I'm wrong to interpret your problem or you're under it. I want to understand what that text is like. Last edited by a moderator: Mar 23, 2022
emanuele grasso Guest Mar 24, 2022 #10 and no I can not send it not being mine.. I find a way thanks anyway
emanuele grasso Guest Mar 24, 2022 #11 always in the field of carts.. Is there a way to adapt a maple (my personal) of type a3 in a maple a0 or a1? Thank you.
Vittorio Guest Mar 24, 2022 #12 emanuele grasso said: always in the field of carts.. Is there a way to adapt a maple (my personal) of type a3 in a maple a0 or a1? Thank you. Click to expand... Of course. you need to know how to build blocks or catalogs with catia
falonef Guest Mar 24, 2022 #15 emanuele grasso said: I keep opening the dwg with empty letters. . boh. Click to expand... What version did you use?
