because in this case we proceed with a "cut with sweep".
I hope it is only an academic study, because threaded holes are made to 99% with the "creation wizard holes" and inserting the cosmetic thread.
What? hhhiih... perhaps it is not clear to you that the masculine "takes" material, does not add it.
If you had used the sweep cut function (as you already wrote massive...) you would have done well.
In any way you should use the guided drilling, modeling as you tried to do is dispersive and, in case of several features, weights the model unnecessarily.
not last the designation in the harvests at the table.
I'll re-allege the file with the sweep cut.
