find and delete temporary files
cacciatorino
today I had to close with the swx task manager after several hours that was processing a pdf 3d file without coming to head, only that left me the file system full of lock ~$part.sldprt file.
Is there a command to purge these files automatically? or do I need to look for them with classic windows tools?
second question: where do you put temporary files that you create during work? Is there a specific folder to go clean every now and then?
certain that yes hunter, in the options there are in the last tabs the voice for temporary files and for backup copies for recovery. choose a convenient local place on a fast drive or if you love the risk and are one that saves a lot, disable everything. :finger:
Good last, I've been working with myself for ten years and I've never gone to recover an automatic rescue! I'd rather do it again, but I actually save a lot.
and instead for lock files? are files that normally do not see why windows keeps them hidden unless you select the appropriate option in windows explorer. so much the files are on the samba server and he thinks of us to prevent competing access.
Great! However remember that saving temporary or backups on servers create lan traffic for nothing and performance decline. by backup I mean the version of the same file that is generated every time you click save....he creates by default 10 versions (I think) then starts overwriting. serve to recover the file to previous changes.
great system. Also because automatic solidworks savers don't work. mai. You lose time choosing the folder, the type of rescue, recovery, etc and when you're seriously nailing the files there are or are damaged. a shame they can't solve since the night of time.
It will be my fault that I have too heavy models, but if I make cubes, I wouldn't need an emergency recovery system. the old summit had a system that always saved the last operation carried out. was his "undo" (yes, limited to an operation:eek:). I know that today would be improposable with dozens of mb files, but the resounding is that once the processor of the workstation died. replaced the processor, at reboot I had not lost a minute of work.
I've got to get them out of hand, they're only left if swx crashes. apart from filling the filesystem table does not occupy space.
occasionally a nice batch file that cleans unwanted files would be useful for each archive. I do it with total commander and a custom search.
I messed up with the instant command 3d and not seeing the piece well in its entirety I saved and then closed everything. But now I have to recover the job as it was before the damage. I look for temporary backup folders but I find nothing (c:\users\606595\appdata\local\tempdirectorybackupsw\\\swxauto ).
Is there a solution or do I have to do it again? despair... .
That folder is, as the name says, a temporary folder.
there saves the instant file you are working, you can only recover it
if the function is enabled (see image) and only for if there was a crash of the pc...
I have adopted the system to make it create 3 files for each entity that at the end of the day are deleted from a batch file before the daily backup.
I'm sorry for you....
If you just don't mind, turn off the instant 3d, it's a moment to make a disaster... sometimes noticing you risk changing the piece so little
that you really struggle to get...:frown:
Thank you, I have activated the option and will not use instant 3d with such lightness in the future
quello che cerchi si chiama :
in microsoft windows, click start, solidworks <version>, solidworks tools, </version>solidworks rx .
I wrote it in English because I know you use it in English.
among the cleaning tools there are those of ms and the appropriate ones.
found, thank you! Strange that the tools start in Italian!
