duken
I started a project of a villa (explained in a video course) and opened the first file where there were only the lines to follow to create the walls.
in the submenu "floors" there was:0-ground floor
1st floor
planimetryin the tutorial I saw that they had created multiple levels and also renamed:1-plant pt
2-first level
3-second level
5-third level
6-covering 2
cover1
planimetrythen not knowing how to do, I duplicated in my file several times "0-ground floor" and eventually I created and renamed the missing submentu.
Well I created the central vault selected in blue, and the guide says to do:
element-- > height hazard--up to level 5: third level.
If I do so, it appears to me in the bond of height only:
1-plant pt
2-first level
and there are no others..(5-third level,6-covering2...etc)
You explain why?
1st floor
2-first level
3-second level
5-third level
6-covering 2
cover1
1-plant pt
2-first level
You explain why?
