first steps
  • Thread starter Thread starter deba7171
deba7171
I am following the first steps with 3ds and the official autodesk guide.
I was studying links and constraints and hierarchy when I had to mess with sys coord.
is in fact that all the elements I create or amount are generated and blocked at the world.
Can you tell me where to help? Thank you.
you accidentally activated the wrong default constrain (I think it's the xref controller).
create any form, even a box, and keep it selected, go to the motion panel, expand the rollout assign controller, select the first item at the top "transform" and click on the button just above (the box that stands between the written "assign controller" and the selection panel), open a window, choose "position/rotation/scale" and click on "make default" and ok
should have returned everything to normal.
Thank you very much. you know at first to force to detach the eye between exercises and search for the function on screen after a while you unleash.
cmq for the moment I step by step to make myself a little aware of the environment. . .
