fitting a vacuum tube
  • Thread starter Thread starter roccolaser
roccolaser
hello to everything I wanted to do a serpentine that starts from the bottom of a reservoir and then climbs me vertically into the fasciame, the fact but then I can't fitting a piece of pipe with the spiral, and get out with a curve and a trunchetto out the virola. I attach an image to better understand....:confused:
on the connection I got a little bit drunk (it was enough a 3d curve), the curve instead is easier.
I attach the file.
Remember that with 3d sketches you can do everything.
mike thanks for the help but I can't figure out how you use 3d sketches, how did you do 3d5 sketch plan 2? Could you show me a 3d5 sketch video like you did?
good morning to all but can in this coil understand how many linear meters of pipe is there?
to make the plan is simple: go to the label "crash" and click on "plan" (for sketch 3d). from the two references, in the case the point that mike drew you in the "schizzo19" and the upper floor.
I almost forgot:
but why did you use the command "should copy"? ?
It's like messing around for no reason.
in 3d sketches you can put the sketch on a provisional plan that you can skill and positions like a "classical" plan.
is present in the "scratch" bar via the special Tastino
I don't know if the discussion is appropriate, if not tell me how I can open a new one!
I am asking another question:
in the company where I work, it often happens to have to deal with works as from photo attached. We should draw a semi-tube that wraps with a helical pattern on cylinder and then with spiroidal pattern on a 2-ray curved bottom. they told me that with inventor you can't do it, or better to say you do it, but with problems then with the study of the flows, I asked if with other media software (solid work/edge) you can do it. I would also like to get the developments and what else. all this because we are considering designing a 3d software. thanks
Okay, but the spiral you have attached, has a narrowing on a hypothetical cone, but in my it is a bombed bottom with two curved rays, and I should keep the " x pass" both on the cylinder and on the bombed bottom for winding the semitube. allego schizo demonstrato
