@neipolos
My name is alessandro I attend the first year of a course its mechatronics. as the first project work, witnessing the work done so far, I am designing a flag crane destined to the naval sector (precisely for the watering of boats). the starting data at my disposal, in addition to the purpose of use of the crane, are the following:
Column height: 5m
Arm length: 4m
max capacity: 2t
for the sizing of the arm I selected an ipe 360 profile, while for that of the column a circular hollow profile with external diameter 406,4mm and thickness 7,1mm.
My problem at this point is to design an arm rotation system that can be connected to an electric motor. I wondered if it could be a suitable solution to exploit the following example (see photo) by connecting the rotation pin (prolonged) through coupling to a motor fixed to the column of the crane.
alternatively I found this other example, where I think you could transmit rotation from the engine (always placed on the column) to the arm through a large toothed wheel placed in the junction.
thanks in advance for the help!
Column height: 5m
Arm length: 4m
max capacity: 2t
