flaggar floating
  • Thread starter Thread starter pianta
pianta
Good morning, everyone.
I have the need to have a particular floating modules always flagged, to make it I must remember, whenever I open it, to make tools--->floating modules and flag.
Do you know a way (config.pro?) to make sure that this option is already flagged at every opening of the program?
So what do you need to ask for floating modules?
with a fixed license (nodelock) are loaded automatically with program startup.
the operation you have asked is to request the use of additional modules on a license server when these are available and not used by other operators.
or maybe I didn't understand the problem when you installed the license with nodelock file you didn't activate anything else... did you?
I have an educational version
the floating module that active is the edu/com converts.
while being tutot on my pc (it works with the detached network) I have to scourge that casellin, I would be comfortable that it was already flagged at the start of proe.
I don't know if I have a fixed license, I have a license server license on my computer.
Let's see if I get it.
When you installed the license server, did you change the license options?
I attach a pdf file with instructions on how to do it.
go to the_install_proe>bin folder, run the ptcsetup.bat and follow the instructions indicated in the attached pdf.
Let me know if you can fix it.
