flashing light on automated manual control medium
mir
Hey, guys.
to what code do I have to report to understand if on a mechanical medium (an arm that rotates and moves on tracks) at two meters height I have to mount an orange flashing when it is in operation?
thanks for the help
The right section is this.
That's what this thing does.
It is a machine therefore looking at the machinery directive and in particular if there are "c" rules that regulate it.
the flashing is a security information system, so according to the analysis of the risks of the machine you will be the one to say whether it is necessary or not (unless there is the reference standard for the medium in question).
Moreover, if you are in the railway field, you must follow the cesifer rules.
However, if you don't describe the object well, I can't help you.
It is not a railway but simply a conveyor belt that downloads in different containers depending on what position it is made to adopt.
the machinery directive remains.
If the thing moves near people (I risk that people get hurt while this moves) I would say that the flashing alone is not good, in the sense that you can't call a security function to a flashing lamp. If the flasher doesn't work what happens?
You better explain why I don't understand what this blinker does.
If it were a forklift, a semotive machine with operator and board I would say ok, but so to nose I don't know.
I hope that the design will help you ... even if only indicative as I cannot put the real machine that is patented :
the long part (arm) can go back and forth (with that horizontal scooter working on a rack) and can rotate on the raddle (motor standing vertical).
everything is controlled by an electrical panel on the ground.
do you know the machine directive?
We are here in application of the machine directive in full and therefore the flashing takes us, but I dare say that it also takes the scarlet in addition to the safety devices of the machine to avoid any dangerous situation.
the machine directive is a one I imagine ... but which specifically handles the handling signaling systems?
Ha!
We're bad here, but you built cars?
right to make clarity:
The machinery directive is a law (coherent standard) which comes from a Community product directive. all machines are subject to the said Directive.
Currently: in Italy the machinery directive was adopted by dpr459/96 (reception of 392/89 and subsequent amendments).
At present, in Europe, 98/37/ce is active (it has not been received in Italy because it is the only text of 392 and subsequent amendments).
from 20/12/2009 98/37/ce will retire and will be repealed from 2006/42/ce. there will be no derogations on the application of 2006/42/ce.
This directive is law (free movement of goods) while rules are voluntary. then one can apply them or not.
to market a machine, to use it, to rent it, you must draw up the declaration of conformity with a whole series of obligations to satisfy.
said this, there is no one (as you say) saying whether to put or not the flashing.
You must, in accordance with the Machinery Directive, do risk analysis (according to essential safety requirements, Annex 1 to the Machinery Directive) and on the basis of the result you decide whether to put certain devices or not.
from what I understand, it seems to me to "imagine" that you do not clearly understand the subject.
attention that selling a machine without declaration of conformity and marking implies not to comply with a law (Italian and European). Moreover many manufacturers make the declaration of conformity without checking whether the machine complies with the directive.
I remember that if an accident happens on a car without all the demands of law are bitter cabbages: seizure of the machine and all the similar specimens sold, fine multiplied by all non-compliant specimens and then takes the penalty.
I hope I've been clear.
Actually, I'm an outside of the company and they have an office that deals with regulations... only that in this holiday period I have to establish a preorder of flashing lights and I thought it was a trivial thing like: "moves" == "motor light" :d
Ha!
The machine directive is a law
... cut...
quoto in toto.
I add 2 considerations:
1- many times who is in u.t., especially if young man and imberbe, has not even dawn on what the machine directive is. not because of him, just because no one ever told him. in the school or the employer
2- Unfortunately it happens very thick, especially in the very small companies, that it builds and sells without thinking about the "burocratic" part and regulations.
for the series "5 minutes of my caxxi", I tell you a small anecdote.
When I was "freelance" I was contacted by a small company in my area to ask for a hand for a little project. I go to them (garage of the house) and explain the work. had already built and marketed some machines.
without drawings... without manuals... without risk analysis !!!:eek:
and the machinery directive? :confused:"
"What?????? but that's why we contacted her! "
If I were in your place I would put both the light device and the cicalin, better be criticized for putting something more than less (especially if it is security).
@mbt: just see what happened to a well-known company that built (it still constructs but only keeps the brand) appliances. Following an accident (breaking of a housewife) the company failed (and did the technical files!!)
@maurom: flashing = danger of mobile elements (serve to signal danger especially for those using headphones or other dpi and therefore not able to hear)
cicalina: it is used to alert and cover the flashing when maybe you are in the light of the day and the lamp is not visible given the intensity itself!
After this course of directive ... I go to relax in front of a sheet of excel;(
Yeah.
But you know, the story is always that.. .
"It doesn't happen to me, because I'm smarter" :rolleyes:
Yes!
The current shirts filter little... and until an accident happens no one moves.
I always recommend to my customers: if you buy a car:
1. not paid
2. make a risk assessment
3. If the vdr is ok, then pay, otherwise ask for safety
do a ddc (of conformity) is like making a self-certification! Who controls that you've failed? No one until your cunning comes down and then they're caxxi!
go to the rapex site to see how much merchandise turns without complying with the various directives.
a flashing never fails, but I think if they build similar machines they will have predicted much more than a flashing.
1. not paid
exact in practice it is regulated as a leasing, without manual, declaration of conformity of the machine and of the individual components do not leave the payments, for my plants the last drawing that is made is in absolute the most important we call it "lay-out security" and without it the payments do not leave.
