flat extrusion on cylinder
  • Thread starter Thread starter Andre75
Andre75
Good morning to all,
I would like to know what method it is best to use to get from a flat extrusion worked a cylinder. to understand better I have a 2d development of a type "raviolator" mold that I should wrap on a cylinder.
the problem arises from the fact that I can't "wrap" a sketch on a cylinder because the command seems unable to lay the curve for more than 60% of the cylinder surface.
in my case I have a cylinder diameter 200mm (development=628mm) on which I can wrap a long curve max 420mm
try using the toroidal bending command that you find under the advanced > insert.
Bye.
