flat model code
  • Thread starter Thread starter Quoque69
Quoque69
Hello everyone,
someone knows if it is possible to attribute a code or number of drawing to the flat model.
I explain better, I buy a sheet with a code (drawing and dedicated dxf) then I send in displacement with new design and code.
how can I manage code change with inventor 2018
thanks to all in advance
I believe that the only solution is to create a set containing sheet metal
or:
aa.ipt, the sheet metal (which obviously contains the development for the dxf) ; therefore the aa.ipt file determines the sheet table and its dxf for cutting
then creating a level lowering, create the relative .iam file which contains only the sheet (obviously in calandar representation) and this new file will be called bb.iam
the only drawback is that you will have doubled files
