flat repetition, does not extend the sheet
  • Thread starter Thread starter bulbodepaja
bulbodepaja
Good morning, everyone!
I have the following problem:
I put on the table a folded sheet and I would like to make the flat repetition view, in the options is present the flat repetition flag but even if the view remains closed.
the problem doesn't always occur so I don't know if it's a program bug or bad sett option.
Did something like that happen to someone? .
in the office from me we are 3 designers and to all happens occasionally the same problem.
read my speeches in this discussion:
http://www.cad3d.it/forum1/showthread.php?p=222547#post222547
Thanks to the answer but in the other discussion does not speak of the origin of the problem,
Can we understand why this happens?
thanks again to availability
He doesn't talk about it, but with a bit of familiarity on the plates, you'd understand... :smile:
make sure you are working with the "default" configuration and not
"defaultsviluppo" (which is created only in case of
you put the object on the table).
99% of the time the problem (unless errors reported by software )
is due to the handling of the "flattened" function that is perhaps activated
or disabled depending on the problem.
As a rule, the piece still bent must be in default configuration and by activating the defaultdevelopment configuration must be smoothed.
If not, check the function of the "flattened" sheet bar.
I know, it's a bit twisted but it's so...
If anything post a file that gives you trouble so I will be more accurate.
:smile:
thank you very much, now I realized where the problem resided, it was the default configuration not activated on the solid.
I activated the function and made the table again and everything works correctly.
Thanks again for the availability.
menomal... I thought I was twisted and cryptic... :finger:
:smile:
Sorry if I answer the question: but where is the default entry and default development?
I have the same problem that I don't flatten the sheet.
I had set 1mm thick, 2mm bending radius...if imposed the radius I cannot insert flat repetition in the 2d?
Sorry, I'm a little confused.
when you create the table of a sheet part, you automatically create a subconfiguration of the default file, which is called default-development. verify that when you are in the development configuration the sheet is flattened.
I think I'm very "de coccio":
on which of the 3 I have to enter the configuration and what I have to check:
Thanks again
Thanks again
go to default development configuration activates flat repetition:finger:
is in the 2d that I need, not in the 3d. when I insert a model and as view I choose "flat recetition" does not put me anything or puts it bent.
go to the default development configuration and flatten the model, the flat repetition in the table refers to the default development configuration in the 3d... you must leave the model flat in the default development configuration, while in the default configuration you can do what you want.
Oh! Finally!
still a little confused though it works: I leave you do not tick the entries in change configuration then in the 2d design I choose as you said default development!
Thank you very much. . always seems to know all the voices of the solid menu then instead... thank you again. Hi.
Oh! Finally!
of nothing, default development is a configuration that you create when you put the sheet part in the table and put the flag on flat repetition, and from that moment the reference of that view is precisely on the default development configuration. :finger::biggrin
Sorry to intrude me into the discussion. . .
to me you no longer automatically create the default development configuration. . .problem just in reality just create a new configuration and flatten the sheet manually and then specify the view configuration affected on the table...but you will also understand that doing this every time becomes frustrating!
Surely it will be my setting problem...but I find nothing!
Has anyone ever happened?
Thank you!
Thank you!
did you check the flat repetition voice once at the table?
ok I noticed that the problem arises only in welding environment...and I don't even propose the flat repetition check in the table.. .
if I put on the table a sheet without other elements instead it automatically proposes me flat repetition without problems... and here appear the default development configuration!
you have to put in the table, make body selection in the sight properties, select only the sheet body, then make the flag on flat repetition:smile:
