flat repetition
  • Thread starter Thread starter Esselle
Esselle
Good morning, I find myself asking for help again. I can't get flat repetition on this sheet, does anyone have ideas?
I recommend using extrusion functions and eventually turning into sheet metal.
I attach an example.tratto.webpCattura2.webpps: If you want to get more help, I suggest you attach screenshots to explain the problem, most of the time
even those who do not have your own version of the prg, can contribute to the solution.
ps: possibly in the screens also insert the feature manager.. .
Thanks a thousand of your mike time, I only had difficulty understanding that to insert the sheet opening function I had to use the command "insert folds". I will keep your advice on the pictures, if I come to "disturb" other times!
Good morning! Actually the above procedure does not work if the starting section is an ellipse seed, which is the profile that serves me. Any ideas?
I didn't really use your model and I didn't notice, however you can always track bows instead of ellipse and the game is done.
Here I am! I tried immediately and I can get a sheet as I wanted, but the flat repetition comes out as from first image and is not correct.. .
see them, what worries me more than Yours problem is that one that helps you post images, files and everything else and instead you don't even put the file... Good job.
Good evening, obviously this detail does not go down.
image allego:
cono.webpafter the last cut you no longer get flat development.
Does anyone have any ideas?
