in total the deleted bodies were 6, the sheets in total are 7 rightly, even the side wallpapers they made them in the sheet environment. .in fact there you have 7 plates.
control what you erased the bodies
In such case that with only sheet metal body you have two flat repetition is very strange. you could clean unused functions (right button on the name of the part in the feature>shaft destroyed...) and see if it goes away, if you want to investigate, otherwise peace with the world and so be itin total the bodies eliminated were 6, the sheets in total are 7 rightly
Sure, I try and tell you.In such case that with only sheet metal body you have two flat repetition is very strange. you could clean unused functions (right button on the name of the part in the feature>shaft destroyed...) and see if it goes away, if you want to investigate, otherwise peace with the world and so be it
