flexible assembly
  • Thread starter Thread starter andrea1974
andrea1974
having a flexible assembly at the table if the ball is in a position then when I move it obviously the pals thrive, overlap etc, there is a way to go behind the new position of the axieme? otherwise how do you put the axieme on him? will always be staggered. . .
other thing: use magnetic lines, they are faster to handle; move n pallini together
I solved it like this: I'll make a fixed set up and call it.. ball. the bond to block it and I only hold it to ball so it doesn't move anymore.
