flipped
  • Thread starter Thread starter ars
ars
I would have a few questions about the floors:
1) Can I create a floor so that the last layer, what I then see in 3d, has a dotted retino (or another) but as a background the gray and not white?
2)I created a floating floor the last layer consists of wooden strips. to make sure that in the 3d model you can see the escapes between a list instead of a uniform surface as I can do?
Thank you. Hi.
1) only with the view in "shaded" mode and adequately set the parameter "transparency"
2) if you only look for "the effect" use a reason that has a double line of separation between the lists, otherwise you have to make a specific family. (not recommended as the file will become very heavy)
Thank you very much. :finger: I managed to solve both problems. for the lists I made some openings in the floor copying them then with matrix.
Thank you. Hi.
Hello, I can ask you how you created the floating floor in revit
Maybe it was enough to change the bitmap of the mapping.
not having any image of match:frown: mine is only
a supposition:rolleyes:
made a test by duplicating and changing the mapping bitmap
