fold lines dxf
  • Thread starter Thread starter ulio82
ulio82
Hello everyone,
I have a question regarding the sheet metal environment. Below you notice the 3d of my carter in which on the longer sides to create flanges and the result seemed more than excellent. the fact is that saving it in dxf for the lamierista I do not visualize the flange fold lines as you can see in the second photo. Where am I wrong?
I apologize in advance to administrators if this is not the right section.
Bye.
side folds don't seem correct.
the image lacks cuts before and after the curved part.
If you send the file we see better....so you can't understand well... .
....when I try to load the .catpart doesn't want to know..... I have a red exclamation point.peccato I would also want to know the quotation of the dxf.
You have to zip and then attach to the message.
done....if the part saves it in dxf as I have already anticipated I do not visualize the lines guide bend
thanks for the advice!.
when I try to open the file signals error in fact on the icon I do not even see the preview.
