andreaf93
Good evening to all,
best wishes for the various holidays of this period.
the problem that I find is not able to find the correct parallel between two sheets. I have two details together.
including the "secondary" code is diagonally inserted to the main code. Obviously making the second fold in the "secondary" code I need the second bending to bring me the particular parallel to the main code. as you can find in the attached photos I find a difference of 2.91°. If I add or remove 2.91° to the current degrees that give me the current inclination of the flange I do not find in 0° and 5.82 (2.91x2) at the time of measuring the two floors.
Unfortunately I cannot attach the project in the event of not making the idea I can draw new details that recreate the same situation.
Thank you very much.
