I suppose you drew the profiles with the thicknesses on two different planes and then you made a loft between the two sketches.Hello, guys.
I did this object in cad and then I imported it into inventor for development on the floor but nothing ... it gives me error and does not develop it ... but it is very simple.
Where can I go wrong?
No, I didn't say that the thickness isn't constant, it's the profile that's not constant, and then it creates a thickness other than that designed, but above all elliptical rays, which are probably the cause of non-explication.exactly as you say... but I have verified that the thickness remained constant by trying in half... you see that I made a mistake!? ! ?
Unfortunately I don't know how to use the inventor but I wonder ... can I proceed with the same logic?
do the two floors and then with the inventor loft join them?
