folder file center missing content
  • Thread starter Thread starter Tarkus
Tarkus
I'm opening an old set of which unfortunately I don't have the file folder from the center.
and of course at the opening it is angry: eek:: alcohol: and tells me that they are missing.
Now I ask, but since they are unified objects, (keys, kits, etc.) there is no procedure to let them search and regenerate automatically, as long as they go to search in the cc one at a time? :smile:
in the project file you have to bet between the libraries to the folder that contains the files of the new content center. If you miss those single pieces, open a blank set, load them from the center and then reopen the original axieme and you should find them in their place.
Good night!
That's what I'm doing!
so much it is worth reloading them in the asses they lack.
What I'm asking, is if there's a procedure to go and recreate them automatically, since it's components that still generate the program...that's when you open a set and you miss a file that you created, and that you erased or moved, it's clear that it signals the unresolved component.
but the cc files, the program already knows where they are, so if you see that they are missing you could ask if to recreate them, rather than stay waiting for a new path.. .
But this is just utopia? ?
or maybe with a macro?
Maybe he didn't like that "good night!!!!" . .
How much susceptibility.
it was not certain to offend, it was only to mark, as I had written in the first post:
"there is no procedure to search and regenerate them automatically,as long as they go to search in the cc one at a time.".....
But then your c.c. is not centralized on the server?
If all your projects point to the same c.c., old or new that is the axieme you should have no problem....or wrong. At least that's how it works.
p.s. attentive to how you answer otherwise I do not speak to you anymore.:biggrin::biggrin::biggrin:
p.s. careful how you answer otherwise I don't talk to you anymore.:biggrin:
Now I bark so I'm also afraid:
No, I have a unique workplace.
the problem is that it was mistakenly deleted the file folder from release 10 content center, (10,non 2010), where the cc saves the created components.
the project, as I think all the projects, points to that folder, not to the cc directly (or at least I do not know the way to point it to us) , so when I open the axieme, it does not find the folder, it does not find the files and tells me to solve the link.
I don't think I'd better say "nothing" to him, and once the axieme opens,
I have to go on every unresolved component, use "replace from cc" and find the component.
So I repeat, or did I not understand anything, or, since it's inventor that if he generates them from cc, when he sees that they are missing from the it-it folder, he could simply regenerate them, no?
I think it's stupid to say, "The skf 6004 2rs bearing is missing, where do I have to take it when it's in the cc that the system that generates it, and so you know where to get it.
I say a fool, but if once I get it all back, you're gonna make a pack&go, and after you've done your parts files, and you're gonna give me a seat where you have them now?? ? Maybe so restores all new connections.
It's an idea, I try...
if the files there are enough to change the project file (the one where you customize the folder, you indicate the agiguntive trading folders, the committed project folder etc) and tell him that the business things point to the folder you indicated? ? ?
No, the problem is that there are no files... they have been deleted.
inventor knows what he misses, but not if he authorises them, he wants to use only those already generated. . .
ma non hai neanche un back-up????
If you think so, I can give you a gigamail from my content center, it's pretty full and could save you a little bit of inkaxxature.
I thank you, but as you were discussing on the forum, I kept charging
missing files, and now I'm done... thanks again:smile:
I've been following the forums for a while and I have to say that in general tarkus knows well inventor and is not a fool. and also in this case hit in the sign.
Unfortunately, inventor doesn't do it alone, but wait for you to do it.
I behave like this: when you start asking me components of the seleziono content center ignores everything. Once inventor opens, select the first missing component and replace it from the cc by selecting "replace everything" and so on.
As you do this job, the cc repopulates and less and less axioms will have problems.
I even entered a company where the famines of the content center ernao more than a "r10", cc", r2013" of which a little it and a little en and I did a good thing: delete all the folders, created on the server a folder "centre contents" that what will also go for the next versions, and eliminate the others. from here on then nook who found a vine or washer missing the replacement and in a short time we reconstructed only one cc, but decent and only with what it served to us (before there was everything).
