folding lines sheet
  • Thread starter Thread starter antoniodc
antoniodc
Hello, everyone!
I have a problem when putting in the table of dieped elements (lamaire).
when I represent the view of the "flat" configuration, the fold lines appear to me in the form of continuous lines.
how can I set that they appear with dotted lines?
do you mean the central line where it would go to press the tool?, in this case if I don't remember badly, you can activate the axes and select the ones you want to keep.
Hello, everyone!
If I'm not mistaken, go to the annotate tab, then press the show model annotation button and go to the reference tab that is the right one among the available options.
you will see the flag of your fold axis appearing in the 2d model.
the continuous lines should always appear to you, which are the beginning and end beam references (inside or external), but as I told you above add the axis of the fold, so that you can keep it as reference for your quotations.
I hope I've been helpful.
