footnote
  • Thread starter Thread starter phelipe
phelipe
Hello.
How do you do in autocad mechanical 2015 edit the styles of the famous director?
but not......
I would like to make a famous director whose color of the text changes depending on the color of the layer, but I just can't...
aid
I know little mechanical now, but... forgive me for a phelipe question.
The directors, when you create them, are all with the color "bylayer".
with mechanical there are automatisms for which certain entities are placed on specific layers with defined the characteristics of lines and text (settable in the dwt model). like classic quotas.
if set the creation of notes with fixed color lines and text da layer, when changing target layers should also change the text.
I would personally make the text with color from block Why:
- mainly to change layers it makes useless the automaticity of mechanical and at that point it is worth using autocad or the autocad commands (dirrapid works also in mechanical)
-put odds and annotations on random layer I find it barbaric and fucilation*
- keeping the line manager da layer and the text from block increases the possibility of pyrotechnic shows with a thousand different colors (exclusively for fanatics, can create dependence, abstain minors and pregnant women. aut.min.ric)
* of course there may also be valid and functional reasons, but I consider them as the bigfoot... If you talk about it, someone has witnessed it, but there is no tangible evidence.
perfectly agree on the part of the shooting, and on the bigfoot, but to me the valid and functional reason was given, and more than once, also on autocad:
Just do this.
and I got tired (for the moment) of fighting against the windmills.
But phelipe hasn't answered yet, nor did he say if he managed to solve......
with dirrapid seems to work.. .
My need was to put notes on a drawing not made by me, every note had to have a specific color that referred to a legend. With mechanical (which I recently used draftsight) I can't, acting on styles, create a color note other than others.
Say hi.
