force effect e autodesk 360
  • Thread starter Thread starter design77
design77
Good evening to all
I asked for some information about autodesk 360 and the mobile force effect application.
How does the first work?
on the force effect possible to have it on pc or windows phone?
Mysteries
with an autodesk® 360 account you can save files in the cloud and then view them and edit them using a web browser or mobile device.
basic access includes:
memoryto create the account you receive 3 gb of free memory. additional memory is available with autodesk® subscription.
display viewview and edit project files 2d and 3d via a web browser using autodesk 360 or with a mobile device using autodesk® 360 or autocad® ws mobile app.
collaboration and sharingshare files with your team. invite team members to view, edit, share and download projects directly in a web browser or mobile device. follow user comments with the flow of continuous activity.
the virtually infinite computing capacity of the cloud allows you to verify the performance of multiple projects and create photorealistic renderings without engaging your desktop resources.
users who adhere to autodesk subscription have access to additional benefits of autodesk 360 for compatible products as well as 25 gb memory per license on subscription
in merito al force effect possibile averlo su pc o windows phone ?
no, per ora.
I am in subscriptions with inventor, so I access 360, I just want to figure out how to use it if someone has already done it.
I read that it can also do stress analysis, but I do not understand how .
Does the force effect work on autodesk 360, or is it integrated into the factory suite?
up.
I would like to inform you that the app forceffect is available in the google chrome market in the form of apps to use in the browser!
I use inventor 2011, and I would like to know if it is possible to change the material of the screws so that when load of the screws in a set I always get the word that I decide example 8.8,10.9 and not the standard stainless steel wording. ....so that when I put it on the table, the component list is already heard with the correct wording.
It has nothing to do with the rest of the discussion, but... just customize the library and edit the material and/or description
